Hello. I'm driving a 1995 Honda Del Sol S with a 1.5L D15B7 engine. It's 140k miles and burning oil + vanishing coolant. Oils can't be found leaking on the ground or anything. The oil vanishes from the top hole to the bottom hole every 120+ miles. Not much smoke comes out of the exhaust either. I've used many types of oils (5w 30, 10w 30, 10w 40) and the thickness doesn't matter. What needs to be replaced and what exactly is the problem? Please help! Thanks
-Jenny
-Jenny
