i just picked up a d16z6 block with a y8 oil pump rebuild new bearings and what not i need to know what kind of head gasket i really need i am going to zealautowerks.com compression calculator i really dont get it i just need to know what head gasket i really need for it going to mount on a d16z6 head on the block but need to know whats the right head gasket who can help me out
n/a sohc with p29
use a stock Z6 head gasket from autozone and you will have no issues at all. get it for the 95 civic ex/si and you will be set you have all stock parts in the motor as long as the head was not cut 20 times you will have no hittin under there.
also scrap that y8 oil pump and put a z6 one or a6 one on there the y8 motors had a oill issues that is why they are junk.
if you need a oil pumpi have a few you know how to get ahold of me.RIP Nick
Originally posted by doitpropa View Posthttp://www.c-speedracing.com/howto/c...c/compcalc.php i like this calc. alotRIP Nick
Originally posted by CTgoldhatch View Postuse a stock Z6 head gasket from autozone and you will have no issues at all. get it for the 95 civic ex/si and you will be set you have all stock parts in the motor as long as the head was not cut 20 times you will have no hittin under there.
if you need a oil pumpi have a few you know how to get ahold of me.mr.snuggles to you bitch
Originally posted by sleepinef View Postkeep it if you don't plan on going turbo, i have heard horror story's about the y8 oil pump tho, i would just buy a z6 oil pump to be on the safe side.mr.snuggles to you bitch
Why does the title say p29 did you use the a1 pistons cause then if so you will have high comp but with no clearence issues (once again if the head has not been cut to much) but if its a full rebuild on a stock motor then screw it go on ebay and get a complete gasket kit for 50 bucks... btw ctgoldhatch can I get one of those oil pumps im building a y7 block with z6 head and pm7 pistons and that's one of the things I need8606177780
Originally posted by delsol860 View PostWhy does the title say p29 did you use the a1 pistons cause then if so you will have high comp but with no clearence issues (once again if the head has not been cut to much) but if its a full rebuild on a stock motor then screw it go on ebay and get a complete gasket kit for 50 bucks... btw ctgoldhatch can I get one of those oil pumps im building a y7 block with z6 head and pm7 pistons and that's one of the things I needmr.snuggles to you bitch
