i have a d16a6 in my 89 crx si..just got the car like 2 weeks ago..previous owner said it sounded like it had a cam because the way it idled..when i got the car it "needed a starter" but that turned into just the battery being dead and not having power to start the car...well the previous owner just popstarted the car all the time..he drove it 4 hours to me..and the car ran fine..i drove the car next day after fixing the problem and it ran really hard for being 1.6 non vtec..well 2 days later go to start the car and its idleing wierd.blowing smoke out of the vc vent.and there is just soo much pressure in the VC..so i cleaned the pcv thats fine..my oil is all good..i checked timing and its off 1-2 teeth
so my question is do you think its the timing being off that is causing this problem??
basically car smoked out VC vent.has alot of pressure in the VC.pcv is clean.oil is clean.car idles real rough like its on a cam..would the timing being off cause this??? im just wondering before i go buy a timing belt and that not even be a possibility...
other things were maybe fried rings.bad valve seals.and what other problems could it be??
also dizzy timing was all the way to the radiator so i think that made up for the idle problems..cuz it only started idleing bad when i put it back to normal
