mini me swap
  • mini me swap
    im looking to do a mini me swap on my d15 can anybody help me out and tell me what i need to do it and how to wire the vtec in
    Get a z or y head, obd1 ecu, obd0-obd1 converter for ecu and distributer, get 4 wire o2 sensor, run the vtec solinoid and oil pressure sensor to the ecu and the last wire to ground. Also get a better clutch, 4-2-1 header, si trans, new headbolts, timing belt, water pump, plugs, wires, cap, rotor, oil, filter, fuel filter...and do a fcuking search. I think there is equal number of articles of mini me swaps to pics of slammed out civics. I could be wrong.
    My work: Flikr.
      thanks sounds like a big job
        its not as big as it seems im doin this myself soon, just collect the parts you need first dont make my mistake
          Its not even a lot 2 do if u do it but I suggest u do wat astroboy said cause its worth it
