ef wont start but it runs
  • ef wont start but it runs
    my hatch will turn over an it has plenty of spark but it wont start... but if i spray starter fluid in it then try starting it it fires right up...wat could this be?
    check fuel pump fuel relay cause obviously if you got spark it has to with fuel somewhere could also be fuel filter basically check anything with fuel
      thats the main relay right?
        listen to see if your fuel pump is turning on, make sure your fuel filter isn't clogged, Check the ground that goes to your thermostat housing and make sure none of those wires came un done.
          lil unorthodox but tyry smakin the driverside dash that if it tstarts then u needa main relay
            not relay it wouldnt spark check filter and fuel pump
            !!!!!ThE GoOd DiE YoUnG!!!!!
              thanks guys...it was the relay...sux cuz it cost $63.76
                wow good luck bro
                  junkyard special ftw bannabanna
                    Damn those main relays! Must be all of the humidity.
                    What junkyards do you use? Any pick your own part ones around here?
                    My work: Flikr.
