ef tranny problems!!!!!
  • ef tranny problems!!!!!
    Yea I posted this b4 but I can't figure out wats the problem,I press the clutch and it feels like there's no pressure like it goes down 2 easy,the tranny doesn't go into gear when I try it jus stays in neutral,wat could it b???????
    did you try adjusting the clutch????????
      Hey that happen 2 me b4 n I got my car towed mad far n come 2 find out it jus needed sum fluid unda the hood check it out man
        umm no fluid in a ef seeing as how they are cable tranny not hydro but nice try lol
        if u turn the car off put it in gear then press the clutch nd try to start it wut does it do ?
          It starts up like it doesn't want 2 but it still does
            Did you try checking your cable? Could be shot, try having somoene look under the hood at the lever while you push on the clutch petal. If it moves only a lil bit or not at all your cable is streching or breaking. Also maybe you could try to adjust the cable.
            My work: Flikr.
              I adjusted the cable,THE cable still moves, I put it in gear but THE car won't move
                So you got it into gear and the car stays locked up? What about neutral? The car won't move in the sense of car still acts like it is in neutral or locked up? If the trans is lockin up when you put it into gear then I am afraid your trans has sh!t the bed.
                My work: Flikr.
                  Sounds like your clutch is cooked.
                    x2
                      Im takin out the longblock and sellin it 4 $100 firm any buyers????
