stiff shifter
  • stiff shifter
    Hey my sifter is so frkn stiff I hav 2 use 2hands 2 put into gears sumtimes can't eveh find reverse nuetral don't even move side 2 side is this because my tranny shot or wat?
    the tranny could be shot, but it could also be your shift linkage... maybe its too tight. thats happened to me before.. but it could also be bent or something.. your best bet is that there is something wrong with your shift linkage
      check the bolt that holds your shifter to the linkage...loosen it and see if that helps.
      NHBP Dc5
      R.I.P Nick (nhswaps)
      Gone but Never forgotten
        did you fix it? keep us updated bro
          Hey sorry I haven't had time 2 check on it I been working 2 muc tryin 2 make that moneys but it actually loosin up a lil n isn't so bad but nowb is making a noise sounds like the way the axels sound wen they or broken but I don't believe it the axels cuz it don't make the noise wen I turn jus wen I take off n shift into 2nd I'm thinkin mayb its the clutch. Wat do u guys think I suld check? Am I only really goin 2 find out if I take it all apart or wat? Lmk maan thnks
            i say check ur rear bracket sounds like something moves when motor torques
              Yes that is true 4 a while wen I wuld rev the engine the whole engine wuld move alil. Neva really figured out wat was wrong cuz everythin looked good I went under the car 2 check the linkedge bout 2 weekend ago n saw the bak mount was missin 2 crews so that's y it was movin all over the place so put them bak in n now it is still stiff do u thnk suttin mite have bent in the tranny or wat?
