hey, i got an ek with a d16y7 on it, i swapped the intake manifold to the y8 and i also put a y8 throttle body.. my y8 manifold is from a 5spd so its got the iacv on the back, and it has the 2 wire sensor for it, so i changed it from 3 wire to 2 wire ...
i dont know wat else i have to do, but i think that i have to change my ecu... so i ordered a jumper harness from obd2a to obd1 and if i go obd1 will this sputtering go off because it just bucks alittle bit and stuff but drives fine, it jumps up and down (RPM) from like 1k to 2k...could it be because the dx ecu needs to read a 3 wire, please let me know asap thanks..
