Yo I jus put a new clutch in my car and it was straight 4 a lil while then it jus stop going into gear wat could it b???????and there is something wrong wit my throttle cause wen I jus tap THE gas and it revs and stays at 3000 rpm and if I press the gas harder it will rev but won't go back down it would stay where ever it revs 2 wat could that b???
helllllllp I don't know wats wrong wit my car
i think the revving is ur tb. or gas cable fraid or sumthin but the clutch sucks umm if u try to push it into gear wut does it do? like my boy broke a spring out of his oem replacement nd it kinda worked like a hydrostatic lawnmower .. like go to push in gear nd the car jus started to roll a lil
this is oddd, did u broke in the clutch man ? or where you beating on it as soon as you put it on ? a clutch is supposed to be broken in for at least 500 miles after you install it.
If u were burning out already and stuff like that without the correct breaking in procedure i believe you may have messed up ur clutch springs, also if u didn't tied the flywheel bolts to specs (14 ft/lbs of torque) u might of gotten one of those loose and it might of fell in the transmission prohibiting then that you get the car into any gear.... my suggestion, take the transmission apart (it's a d-series, it only takes like 1 hour to take it apart) and check everything out, as of the idling, check your aicv, throttle body and throttle body cable as well.
When you have done this, please let us know what happens. Also take some pics of the clutch or tranny when u take it out if possible so we could see the real thing instead of just trying to imagine what it should be or look like.Too many past cars to list :P
Alright, Sounds to me like you have a damage Clutch Slave Cylinder. Check to see if you are leaking brake fluid/Clutch fluid off of the slave cylinder. Just move the black boot and touch the inside if its wet or let a friend step on the clutch to notice any fluids leaking.User name is no longer in use! New User name is POGIMOTO!
