91si transmission bolt holes
  • 91si transmission bolt holes
    So the guy I bought the car from was not able to put the correct bolts in the correct holes and subsequently stripped the front bolt and hole out, broke one bolt off in the trans, and the third (rear drivers side hole) he broke the back quarter of the casting off of the trans housing. Do you guys know of any way I can get the rear trans mount to be useful again?? I was thinking I can try to tap the stripped hole and put in a bigger bolt and try to get the one that is broken off out.
    My work: Flikr.
    heli-coil is your best bet!
    NHSWAPS13203 > *
      Do you know a trick I can do to keep the front trans nut and bolt (that go thru the mount) to stop falling off? I have to tighten/replace about every 5 days :(
      My work: Flikr.
        i got a cable tranny case u can switch ur gears into if thats wut u need
