Motor swap, Distributor question
  • Motor swap, Distributor question
    I have a 97 Ls motor im gonna be putting in my 92 hatch. The guy that had the motor before used a single cam distributor I believe because the bottom two holes don't line it its held by the top bolt only. I want to fix this, should I buy a obd1 distributor or a obd2 distributor? Im going to be using my stock wiring harness and stock obd1 p28 ecu.. Also will I need to get the jumper harness for the distriubtor? Thanks in advance
    Need to get obd1 ls dizzy and may need to change alternator to obd1 or splice obd2 plugs to your obd1 harness( not recommended) goodluck.
      Can't I just get a obd1 LS distributor? Same with alternator and injectors with the stock civic harness? This is my confusion
          And why run a p28? If ur not vtec
            My mistake I have a po5 not p28
              Thanks for response h22steaksauce
                Just use a p75
                integranation member #8
                  P05 is a single 8 valve ecu if im not mistaken
