Broken bolt in thermostat housing!! Help!!!
  • Broken bolt in thermostat housing!! Help!!!
    Wats up guys so I was tighten my thermostat housing after changing, I tighten one too tight, now there's half the bolt stuck in the thermostat housing on the engine side...
    Is there an easy way to remove this? Beside an extractor which I tried?
    Can that side of thermostat housing be replaced easily?
    Any suggestions help please thanks
    Drill it.
        you can replace the housing/waterneck if need be
          Thanks, it's a 95 gsr. do u know if all b series are the same? I doubt they have one for my motor at the junk yard
            Any advice on how to get it out? I cNt fit a socket in there and thr open end has no space to turn
