Help?? Please??
  • Help?? Please??
    Hey I put a jdm b20 swap I picked up for my 99 civic ex sedan I doesn't wanna rev pass 4000rpm think I did everything rite have a obd2b to obd1 ecu jumper harness running running a p75 ecu I have a 2000 crv dizzy on it tried change a couple throttle body I had laying around with good map and tps sensor also change iac sensor and still does the same kinda lost don't have any idea what to do.
    Ur in limp mode see if u have any codes
    http://datingsidorsingel.com/
      Help???please???.
      What does limp mode mean and I read the codes and it said iat sensor came on 02sensor also try changing that sensor and does the same
        text me 2032158996 its most likely something simple
        RIP NHSWAPS13203
          Limp mode is when the ecu puts the car is safe mode so u dont do damage:: so u replaced the 02? Or iat?
            I change the iat yesterday I tried 2 I had laying around and gonna change the 02 sensor today when I get out of school
              Start with new parts dont just toss on what ever u have laying around
                How's your wire harness look? Check the ecu connectors and the jumper harness for pins pulled out or filled with debris. If the harness has been disconnected/reconnected many times it can become weak and wires may not contact where they're supposed to. Where'd you get the ecu? Has it been chipped?
                  Got the ecu from my brother swap cam out a running car that was driving perfectly fine ecu a stock p75 car was driving perfectly fine with my single think I'm gonna just put it back tried everything I know and still doesn't wanna work and my wire harness is good
                    Just because this situation happens a lot...make sure your TPS and MAP plugs aren't switched with each other because they do utilize the same plug type.
                    Hidin' out
