Hellpp b20v in ek
  • Hellpp b20v in ek
    Soo I recently swapped a b20v (b16head wit itr cams) Into my ek. Running a chipped p28 . The swaps clean no leaks at all. The car cranks but doesn't turn on. Checked spark, grounds , timing and fuel n everything is workin like it should be doesn't turn on. The fuel pump activates. When I have the chipped p28 and I turn the switch to start the car the chek engine light just stays on doesn't shut off n come bak like it should wen first starting a car. However I install a obd2 ls ecu n chek engine shuts off n comes bak on(like it normally should) any input will help. Thanks in advance
    Where are you located? Text me 2032158996 I can get it running for you.
    RIP NHSWAPS13203
      Try a stock p28. Maybe something is wrong with the ECU
      RIP NHSWAPS13203
        Ecu is fried
        Follow me @bolacan413
        Follow the build @k_insight
          I'm from mass I guess I'll try a different ecu but I put on my boys other chipped p28 n did the same the chek engine just never went off wen first turned the key n had switch on. But shouldn't it at least turn on wit a ls p75 ecu? Wen I tried the ls chek engine turns on n off like it normally does but didn't start it either
            Stupid, but make sure your firing order is right.
              ^never thought of that I'll try that first thing tmrw at this point any advice helps lol
                ide give some advice but youve done basically everything i woulda tried, interested to know what the problem is, GL
                EM1 Clone build http://ctvtec.com/showthread.php?t=93468
                  Thanks bro ya I'm clueless on wat it could be I just found that chek engine shyt MADD weird first time I see that but ima chek the firin order today n if I find out ill post it just In case it ever happens to anyone else bumpp
                    Who burned the chip in the p28? if the crank sensor is turned on the car wont start.
                      Obd1, doesnt matter. And you can't turn it off in options or anything.
                        ^^ gdlks was just bout to say the same
                          Firing order yes, but
                          Check crank position sensor
                          Curt
