Help !!! LS non V
  • Help !!! LS non V
    i have an ls non vtec that doesn't let me rev past 4,000 rpms. i was reading some other forums and it said it might be the distributor .
    Have you tried a different distributor?
      Is it a stock ecu? or chipped?
      Did it start out of no where or is the swap new to the car?
      Is the speedometer working?
      Does the tach jump around at idle?
      what kind of car is it in? obd1 or 2
        Here is a good starting point.
        Honda CRX / EF Civic (1988 - 1991) - 1991 Civic. b18. wont rev past 3500? - Its Throwing cel code 14. ICV. it idles just fine. but wont rev past 3500. and if i take the ICV of and start it it idles at 3500 like launch control or its hittin rev limit. cleared the ECU sever times. dirty ICV? anyone know whats up?
          Its a chipped ecu, i swapped it couple weeks ago. Its an OBD2 motor but an OBD1 ecu.
          It idles great. and my car is an obd1. 92 hatch
          i have not tried a new dizzy
            Probably tps
              Can I adjust it? Or do I need a new tps ?
                Did this happen randomly? Do you have a check engine light? Does your speedometer work? Does your ecu have launch control?
                  it happened after i put the motor in and had it running. and yeah i do have a check engine light, it turns on after drive for like 10 minutes or so. and my speedometer does work. and no my ecu doesn't have launch control
