I plan on upgrading my exhaust setup in my gsr soon right now I have dc sports 4-2-1 headers everything else is stock
I found a decent exhaust system 60mm (2.36") that I plan on getting I also have a first gen skunk2 intake manifold port matched to a 65mm throttle body I will be installing along with a set of 2001 ITR cams and valve Springs I'm also running on a Obd2a p73 itr ecu to keep my car emissions compliant so plan on getting a high flow cat as well
My main issue is all the 4-1 headers I find have a 2.5" collector will that cause bottle necking in the exhaust since it's 2.36" or will it be fine also would i get a hi flow cat that matches the collector or exhaust diameter
