front end vibrates alot
  • front end vibrates alot
    the sound comes from drivers side, sounds like its coming from timing belt area, sounds like a whom whom.... whom.like off and on.
    my throw out bearing is brand new and has plenty of grease.
    i was thinking maybe timing cover is rubbin or maybe mount not bolting on all the way? cuz all my mounts are good and i have a energy insert in the back.
    95 integra ls- dd
    03 types sold
    96 tegra ls -sold
    Sounds like a Bad Left front wheel bearing.
      ahh never thought about that, I'll have to check that out, thanks
      but if it isn't that?
      95 integra ls- dd
      03 types sold
      96 tegra ls -sold
        If your front end shakes, & you have that "whom whom" sound, I can almost gurantee you that your wheel bearing is toast. Does the noise only happen when the car is moving?
          no see that's the thing, when the engine is running and i like pull the motor back or put weight on it, it goes away
          95 integra ls- dd
          03 types sold
          96 tegra ls -sold
            could be bad back motor mount..
              i said there all good, no rot or cracks,im think its maybe an axle? and its coming from driver's side, i also have energy inserts, couldn't possibly be timing belt cover?
              95 integra ls- dd
              03 types sold
              96 tegra ls -sold
                yeah so i was installin my torque damper and i saw that one of the gromets nuts was off, on top of the valve cover, luckly, so i put it back on and no vibration, it was on the driver side too, next to cam gears,, which i was also leakin oil,
                95 integra ls- dd
                03 types sold
                96 tegra ls -sold
                  yeah you guys were right my driver side mount is broke, the rubber ripped right out, so my engine was saggin and probly hittin the hood. time for some solid mounts!
                  95 integra ls- dd
                  03 types sold
                  96 tegra ls -sold
                    thats an easy fix
