ok im thinking bout buying my buddys b16 vtec head. im new at this all n i was jw wat i need to do the swap. besides the head obviously. do i need a new intake mani and turbo manifold? im going from a stock ls head to the b16? i also no ill need gaskets. thanks 4 the help
b16 vtec head swap
• VTEC Cylinder Head Assembly (B16, GSR, ITR)
• B20/LS Block
• B20/LS Head Gasket (depending on which block you go with)
• Stepped dowel pins
• Cylinder Head Drain Plug (1/8” NPT plug and tap)
• VTEC Oil Supply Line
• GSR/ITR Head Studs/Bolts
• LS/B20 Water Pump and Timing Belt or GSR/ITR/B16 Water pump and Timing beltknuckk.
