b20v in ek bogging
  • b20v in ek bogging
    whats goin on ctvtec been having some issue with my motor ever since i swapped it i tried numerous things and still havent figured out what it is its a obd2 b20v in a 2000 ek ever since i swapped it into my ek it hasnt ran like it should its fine when i give it a lil gas but when i give it alot or floor it, it bogs out badly it cant be the motor its self because when it was in my EG i had no problem with it but as soon as i put it in the ek its been giving me that issue
    im using an obd2b single cam harness on it
    What have you checked on it so far?
      changed the dizzy harness changed the computer and changed the plugs
        im thinkkn it could be the fuel filter or the engine harness but to get a dohc harness would be a pain in the ass for my car
          Yea check the stupid shit first before trying to get real technical are you using different size injectors or anything
            check ya harness i had the same issue came up to be a couple of things bad rotor clogged cat and my iat kock and this other vaccum sensor were mixed up i say check around the intake maifold area and make sure ur clips to ya sensors are correct gl i guarrantee its one of the things i mentioned
              im using gsr injectors
              im thinkin its the harness to next day off im gonna take a real good look at the harness cuz its pissin me off i dont have thay many vacuum lines because i have a skunk2 intake mani
                Could be a tps
                  Could be a tps
                  it didnt do that in my eg tho so it couldnt be a sensor
                    If you had it in your eg you were running it on obd1 when most sensors go bad on obd1 it won't effect the motor but now in a ek your running it in obd2 and with obd2 cars any stupid sensor gone bad will make your car run sloppy
                    J.R. Built not Bought
                      yea man check ya harness i had 3 sensors pluged up the wrong way so im sure it has to be the harness bro as soon as i fixed it the lag an the sputtering stopped so my main guess is there and also check the iat wich will make you run like shiet that can also be bad keep us posted!!
                        I have a 00 ek b20v was running like shit until I got step down harness to obd1 ecu
                          i have a stepdown harness already
                            is some sensor guaranteed. i cant remember which one they are but they're are 2 sensors on the intake manni and if they are swapped it can run like shit. theyre the same plug so its easy to plug it into the wrong one.
                              do you have a cel? start with that.
