Well i got this code meaning is a knock sensor malfunction but i swap the engine for a jdm engine and theres no knock sensor in that block now theres any bypass i can do. Or can i just get a sensor and conect the plug and put close to the engine? This sensor only reads the vibrations idk what to do can anybody let me know if they went thru this
P0325 code
Change ecus. If your doing it for emissions purposes the best thing to do is run a LS Ecu. If not then jump to obd1 get a chipped Ecu and get the car tuned and the tuner will dis able the knock sensor. If its a stock engine then run a base map and dis able the knock sensor. Or you can drill/tap the alternator bracket and mount the sensor there.Money ain't a thing! Crew Member #1
Originally posted by LS/Vtec View PostChange ecus. If your doing it for emissions purposes the best thing to do is run a LS Ecu. If not then jump to obd1 get a chipped Ecu and get the car tuned and the tuner will dis able the knock sensor. If its a stock engine then run a base map and dis able the knock sensor. Or you can drill/tap the alternator bracket and mount the sensor there.
Ps. The ls ecu dont read the knock sensor?Comment
Anyways ill jus put the knock sensor like you said in the alternator bracket or anywhere else where it can feel the vibrations of the engine thats all that sensor is for thanks for the lookout
The info came from the last person i expected on this site thanks ls/vtec good to know theres someone with knowledge on this forum that slowly im loosing interest forComment
if it's for emissions then run a ls ecu. It wont hurt to mount the knck sensor. But it'll be easier to just plug in a ls ecu, drive for a hour and then run thru emissions. LS ecu doesnt look for knock sensor. Thats what I always do for emissions. But i'd just run a LS ecu It's the easiest/quickest way to pass and get it over with.Money ain't a thing! Crew Member #1
