car wont start...
  • car wont start...
    ok its my turn...just put my motor back in everything is done by the book...
    i got power spark and fuel but shes not startin...any thoughts...
    2o3 crew member #30
    93 captiva DA9
    GHK all day #7
    RIP NHswaps13203
    Do you have your Timing Right? Do you have your valve clearances set? Do you have compression? Let us know.
      relay ? ecu?
      *S14 Kouki *
        check all the grounds. top ground, tranny ground, thermostat ground
        ~StayinFRESHSINCE1982~
        SPUNKY MONKEY CREW MEMBER #1
        203 CREW MEMBER #33
          If the motor has been sitting for a long time the cylinders may have become dry and the rings are not sealing, check to see if you have compression.
            ok so ive been messin with it and aint gettin anywhere...
            -i checked the main relay for the 3 clicks ...good
            -timing is right
            -did not check compression yet
            -as for valve clearence the head came off of the running car and just sat for a lil while and went back on
            -all fuses are good
            -i have spark and fuel through the fuel rail
            she cranks but wont start...at times will give a lil hint that it wants to but thats it
            2o3 crew member #30
            93 captiva DA9
            GHK all day #7
            RIP NHswaps13203
              i just put the whole bottom end together to the haynes book specs but didnt check compression yet
              2o3 crew member #30
              93 captiva DA9
              GHK all day #7
              RIP NHswaps13203
                Sounds like the firing order to the dizzy is wrong!
                  i went over it a few times and the firing order is right...and i also have taken the fuel injectors out and they all spit fuel. am also trying a brand new dizzy and have the same problem
                  2o3 crew member #30
                  93 captiva DA9
                  GHK all day #7
                  RIP NHswaps13203
                    Compression? Valve clearances?
                      havent checked the compression yet and im not sure how to check valve clearence but the head wasnt touched when i took it off not sure if that matters
                      2o3 crew member #30
                      93 captiva DA9
                      GHK all day #7
                      RIP NHswaps13203
                        so check the compession.
                          no compression rings werent seating ...shes runiin thanx fellas
                          2o3 crew member #30
                          93 captiva DA9
                          GHK all day #7
                          RIP NHswaps13203
