I have and obd1 gsr swap that i want to put into my ek hatch thats obd2 will i still pass emissions even tho my car wont be obd2 anymore?
Obd2 to obd1 emission ??
You need to switch the injectors, alternator, and distributor to obd2. You will also need to run an obd2(a for 96-98 and b for 99-00) P72 GSR ecu. You can't come through emissions with an obd1 ecu in an obd2 car it will fail. I do emissions, that's how I know this.
Also make sure you do NOT have any check engine lights for anything. If you need anymore help PM me.
Originally posted by Lsvhatch View PostDamn gotta get mad stuff lol sucks i just got a brand new obd1 dizzy a month ago what about a knock sensor?
But the easiest way to take care of it is to do a CKF bypass. Quick and easy and all you need is a couple wire splices. Look it up on google.
Originally posted by jdmjunkie9753 View PostYou need to switch the injectors, alternator, and distributor to obd2. You will also need to run an obd2(a for 96-98 and b for 99-00) P72 GSR ecu. You can't come through emissions with an obd1 ecu in an obd2 car it will fail. I do emissions, that's how I know this.
Also make sure you do NOT have any check engine lights for anything. If you need anymore help PM me.:cool: Luis Carrasco
