Need help and advice
  • Need help and advice
    ok here is the deal...
    just picked it up for 1500.
    i just picked up a 1991 crx si with a jdm obd0 b16a. I bought the car for the motor for my 2000 civic ex. so basically i want to take the d16y8 and put it in the crx to resell and take the b16a and put it in the civic ex. My questions are
    1. what will i need parts wise to put the b16 into the civic?
    2. what will i need parts wise to put the d16y8 into the crx?
    3. what kind of wiring am i going to need to do for the crx?
    4 what kind of wiring am i going to need to do for the civic?
    5. Should i swap the b16 to obd2?
    I work in a garage so i have the space and tools to do what i need to do.
    I have swapped before but i haven't swapped obd0 to obd2
    thanks for the help
    so i did a little research and this is what i found...
    b16 into 2000 ex i need
    99-00 civic si
    ecu
    dizzy
    t bracket
    driver side motor mount?
    94-01 teg
    axles
    shift linkage
    Does that look correct?
    what am i missing?
      you need
      99-00 SI T bracket and mounts
      99-00 SI shift linkage
      integra axles or 99-00 SI axles
      99-00 SI ecu
      you will also need to do a crank sensor bypass because that motor will not have it
      you can run the stock EX harness
      and you will mee a 99-00 SI dizzy.
      also you will need a hydro trans or talk to nice guy about swaping your cable trans guts in to a hydro case.
        to put the Y8 in the crx
        you need cable trans
        sohc axles
        sohc crx or hatch shift linkage
        you can use the harness that is in the crx.
        you need some obd0 injectors
        obd0 dizzy
        obd0 ecu
        and mounts
          you need
          99-00 SI ecu
          so other than switching the injectors from b to d and bypass the crank sensor and use obd2 b dizzy and alt will everything else plug and play with my ex harness?
            sohc axles
            obd0 dizzy
            obd0 ecu
            and mounts
            i have decided to not go this route.. will be selling separately
              your such a ricerr
                Originally posted by gsr17y View Post
                your such a ricerr
                Lmao
                J.R. Built not Bought
                  should have just bought a b16a2 swap lol
                    Make it look stock and keep the crx it looks pretty clean besides the rice kit
                      your such a ricerr
                      thanks d bag
                        It looks like a mugen kit kinda from the side
                          Originally posted by ls94civic View Post
                          thanks d bag
                          your welcome dick lick
