ls swap help emmissions asap fml
  • ls swap help emmissions asap fml
    i have a 98 ls b18b1 and 99 ek what engine harness should i use to pass emissions i have a ls harness and a frankinstiend cx harness and what could i do to make it work .
    i would assume you need a obd2b ls harness and ecu. then its all plug n play and if everything is plugged in should have no lights.
    Originally posted by lsj203
    Can I make payments???
      modify the stock harness from your car & run a jumper harness with an obd2a p75, unless you have an obd2b p75 with the imobilizer disabled
      MR Automotive
      Dave's Tuning FTW
        will jumper communicate with obd port?
          He doesn't have this car anymore
          Always on that fire
            jumper harness is just wires u can use to pass if u down grade obd2b to obd2a because they look for same sensors and use the same code reader.
            Text:8604810204
