Okay CTv,
I am having a major issue with a project car I am doing.
Hopefully you guys can give me some light on this with your experience.
Make: Honda
Civic
CX
Motor: 99 GSR
Engine Harness: 99-00 SI
ECU: P72 99 GSR
Using a Jumper Harness
My issue is that the DLC isn't connecting to the Obd2 scanner to see why my check engine light is on.
I'm not sure if there is something else that I need to change or one of the PINOUTS on the ECU need to be switched.
If someone can shed some light on this issue or know of a website that can help.
Any one do this swap and have the same Issue?
Everything is Obd2
Make: Honda
Civic
CX
Motor: 99 GSR
ECU: P72 99 GSR
Everything is Obd2
![violin](https://www.ctvtec.com/core/images/smilies/anim_03.gif)
