ls turbo or b20 turbo???
  • ls turbo or b20 turbo???
    ok so in thinkin of gettin a low compression b20 motor and boostin it about 8 lbs... i already have an ls motor..... should i get and boost it or boost the ls motor???? im gettin the motor from the engine depot in jersey so its gonna be mint... any advice??????? any info would help...
    i say boost what u got and get it tuned or it wont last
    R.I.P Nick aka NHSwaps
      well either or im gettin it tuned... ive had thousands of ls's tryin to do suttin different.... plus im gettin a good deal for it..
        I did bone stock b20 turbo 7 pounds with a dave tune it ran good..i still got the ecu wtih the tune on it 4sale
        WILSON BUILT
          thats all i wanna do is like 7-8 pounds... everybody keeps sayin their shity but not everybody tunes their cars... im defenetly takin this to be tuned... i think i might just go with the b20 try it out... if it blows then i build it....
            B20 have weak sleeves thats whay everyone says there bad. Do a compression and leakdown test on your ls motor, if its good id say turbo that motor.
            But if you wanna make power sleeve the b20. If you sleeve it you might aswell buy low compression pistions, rods, head studs and a thicker head gasket. There good for around 500chp with those components. And they have crazy torque when there boosted and TUNED PROPERLY.
            Id also suggest going B20Vtec since the b20 heads dont have fantastic flow charicteristics.
            Honda's SUCK!
              those are my plans goin b20 vtec ...the motor im gettin is the low compression one so im thinkin it should be str8 with a good tune... im only doin bout 8lbs max... im not tryin to get 500 hp just wanna get a nice lil pull....
                well alot of ppl always say to go b20 vtec because its the best bang for your buck..if you have the money to do it then do it..if not then keep the ls and buid it and slap a vtec head on it and boost the sh!t out of it..i am doing a ls vtec and i kno dat b20 vtec would have been stronger but hey i saved a few bucks by keepin my ls..so its your choice...just go 4 it
                  You shouldnt base your power goals on PSI. What makes and breaks motors is horsepower, but if you have a good conservitive tune with numbers around 250chp youd be fine on a stock motor.
                  You only need to build it up if you plan on making some numbers past 300+ hp. Thats when you typically max out your head bolts, rod bolts, head gasket and eventually sleeves and pistions.
                  Stock pistion ringlands are also very weak on these motors.. They dont hold well to much detonation, same goes for the sleeves.
                  Im in no way trying to steer you away from this setup, just pointing out some weak points for you and others to know. Incase you or some one who reads this thread does build a built B20T, then theyd have adequte info on how to do so.
                  Eric
                  Honda's SUCK!
                    Eric
                    thanks for the advice guys.... really appreciated... ill prolly do the b20 and keep my ls just in case... never had a b20 b4 so prolly just gonna try it out...
