i just bought an 01 integra ls, bought it without a key, but i took the ignition apart to be able to crank to turn over, it turns over and sounds like it has no compression. i took the timing belt cover off to check the timing which was way off, water pump looked to be leaking but wasnt locked up, but then noticed the splines on the crank pulley (harmonic balancer) were all stripped down and there was no woodruff key. so im thinking about getting a new crank pulley and key. putting it back together and hope for the best. anyone have this happen or have any input or help or ideas why this happend in the first place.
01 integra help
Originally posted by civicefsi91i just bought an 01 integra ls, bought it without a key, but i took the ignition apart to be able to crank to turn over, it turns over and sounds like it has no compression. i took the timing belt cover off to check the timing which was way off, water pump looked to be leaking but wasnt locked up, but then noticed the splines on the crank pulley (harmonic balancer) were all stripped down and there was no woodruff key. so im thinking about getting a new crank pulley and key. putting it back together and hope for the best. anyone have this happen or have any input or help or ideas why this happend in the first place.Originally posted by boostedej6been a member for ten seconds and he is being a dick....... he got ctvtec down.
Originally posted by CiViCDRiVEr99 View PostIt could be the fact the 2001 has a chip in the key that signals the computer to start since u don't have the key with the chip it's not gonna crank over
cars cranking over but sounds like no compression so it should atleast try to sound like it wants to start its not an issue with the key which i will be gettin hopefully this week95 teggy ls turbo DD:)
Originally posted by 93supercoupe View Post01 integras have an immobilzer. it will just sit there and crank but ever start. You can remove the immobilizer but it will have a CEL unless you get a blank chip.
i understand it does but that wouldnt not cause it to crank fast and easy. just imagine an engine that has no compression crank over it cranks over very fast and easy. thats what this was doin, all valve springs look alright i dont think valves bent or anything but im not sure yet95 teggy ls turbo DD:)
Originally posted by civicefsi91 View Posti understand it does but that wouldnt not cause it to crank fast and easy. just imagine an engine that has no compression crank over it cranks over very fast and easy. thats what this was doin, all valve springs look alright i dont think valves bent or anything but im not sure yetOriginally posted by boostedej6been a member for ten seconds and he is being a dick....... he got ctvtec down.
