99 civic jdm b16 wont start cold help!!!
  • 99 civic jdm b16 wont start cold help!!!
    I have a b16 in a 99 civic,when i first did the swap everything was mint,then after a year i started having over heating issues,so i did new radiator,hoses thermostat,water pump and finally a new head gasket,after the re-install when i go to start in the am if its chilly out it'll start then shut off then its hard to start,just cranks and cranks i smell fuel also,so i know i get fuel,later in the day when it gets warm it'll start and stay on,what can be the cause of this,someone spread me some info please,thanks in advance....also i replaced the ect sensor,tps sensor and iat sensors...
    Powered by EF and EK blood!
        Someone has had to have this same issue!!
          u gotta give a little more info new plugs fuel filter ect. do u get good spark? if everything was mint before the headgasket id go back over everything to make sure everything got put back and hooked up correctly.
            Glwi
              Cts?
                Sorry,i've done plugs,distributor is 1 yr old,fuel filter was changed during swap,i'm runnin a p2t for emissions purpose.
                  Dose the car get good spark?
                    When it doesnt start,i havent gotten the chance to check spark,due to the fact that i'm alone at that moment.
                      Id check it i had a dizzy that would act up every time it was cold out i just ended up getting a new dizzy so i never found out if it was the igniter a coil or one of the sensors but when i replaced it the problem went away. Your particular problem sounds like something a lil diff but id still check to be sure.
                        Cool thanks for the reply,i'll work on that and if any solutions i'll update the info,thanks again.
