NEED HELP! Car idles wierd
  • NEED HELP! Car idles wierd
    i have a 94 civic dx with a 96 ls swap just changed the intake manifold so i did not have that extra sensor on the top i have tried 3 iac sensors the car idles from 2000 rpms and drop to 1000 rpms and them back to 2000 rpms and so on or sometimes it holds at 2000 rpms and only drops once in a while to 1000 rpms also i only throw the check engine light after the car warms up.
    I think that i have a 92 integra wiring harness please help
    did u swap the tps and iacv plugs ?? unplug the iacv nd if it idles u no that ur prob. when u unplug it it will idle higher but it'll idle .. plug back in it starts messin up .. u figured it out.. then i'd say try switchin tps and iacv plugs i made that mistake b 4 . it haunted me 4 a month b 4 my boy figured it out 4 me
      didn't c u said u hadda c.e.l. wuts the code?
        i am not sure either a 4 or 14
          nvm that u got
          a. crank angle sensor if code is 4
          b elec. air control if could is 14
          not positive but i think crank angle sensor is in dizzy .. (i'm not no guru at this but im pickin it up lol )
            # 14 says iacv on a diff forum i understand that easier ... i say try unplugging it and see wut it does ...if it makes it better try switching w/ tps plug
              Sounds like you may have a Intake Vacuum leak. Spray asome brake clean around the intake & throttle body gasket, & also spray around the intake manifold itself. If you find the car to bog when sprying brake clean in a certain spot, that means you are pulling additional air into the intake stream, & the IAC valve cant settle the idle speed because there is too much air getting in the Intake stream.
                bump neva i even thought of that good shit man
                  :pthanks leak at the intake manifold i was dumb and cheap and i did it mad late so i made my own gasket with that black rubberish shit instead of buying one so i bought one will do in a few days i will update if that was it i think so though
                    nice man go kyle 4 figurin it out ... pisses me off i didn't think of it had that happen many times ...
