So i just installed a 255 in my hatch and it doesnt wanna stay running. it seemed too lose just a little power in low end and top end in vtec it breaks up sometimes. car doesnt wanna stay running for shit at idle. Fuel pressure was 45psi before the install and like 60 or 70psi after. test drove it that high, wanted to stall every couple seconds, when not on the gas. turned it back down to 45psi and still the same thing. Im running on stock injectors.
Also before the install i was loosing pressure and sometimes my car would want to idle real fuckin low like 200rpm and psi would go 45psi down to 35-40 when i revved it up. I installed the pump and fuel pressure is now going up as it should but car idles even lower and doesnt wanna stay runnin like i said. Soo please ctvtec guru's help me out idk wtf the issue is
