Hazport bolts ? Ina gsr
  • Hazport bolts ? Ina gsr
    I have a dc2 jus bout hasports I wanted to kno what size bolts to buy for the rear bracket and tranny.tranny has no studs eaither jus steal inserts lmk ASAP thanks
    Go to Honda or Schaller acura and order them. you can't buy the proper grade bolts at autozone or home depot. Motor and tyranny mount bolts are one type.of bolt i would recommend getting the proper grade.
      Hasports.
        Bump but aren't they different sizes then oem
          No i don't think so
            I was told that because the oem mounts are thinner and hazports are more bulky and need washers ext ? Thanks for everything
              Hasport. It is spelled with a "s" not a "z"
                It's auto correct bro my bad didn't know I needed spell check
                  You need longer bolts for the rear mount to bolt to the subframe they come with them when you buy the mounts new.. if you have any honda bolts laying around just find some size 14s that fit
                    Thanks bro ^
                      They are 14mm heads not 15mm.
                        Definitely 14s my bad on the typo doin this on my phones small screen
                          Trolling the shit out of this thread Lmfao!!!!
