Emissions help!
  • Emissions help!
    I have a jdm b series motor in my 96 ek. What ecu would I need to run or what's the easiest way I can pass emissions? I was told to run a ls ecu but idk how true that is?
    J.R. Built not Bought
      What b series? Odb1? 2?
        Gl bump
        ~D Block~
          if you have a non vtec engine you would have to run an obd2a ls ecu, if you have a vtec engine then either an obd2a gsr, obd2a del sol b16 ecu, or an obd2a ls ecu. You have to make sure you have a cat, both o2 sensors, & if running a vtec ecu you'll need knock sensor to be wired as well... if you need any help with wiring lmk
          MR Automotive
          Dave's Tuning FTW
            Its a obd2 .. I tried the gsr and cel was on. Also I still have a cat with the o2sensor. Thanks for info have to find and ls or the b16 to try it out nd see
              what was the code that came up
              MR Automotive
              Dave's Tuning FTW
                x2 obd2 takes 2 o2 sensor's so if you only have 1 that could be an issue or it might be the crank sensor..
                  Plus its vtec
                    Like 4 or 5 codes came up it I know one was o2 sensor but its pluged in so I don't know why it came up and I forgot the rest
                      Plus its vtec
                      that wouldnt matter if your getting cel with both vtec n non ecu's its obviously something else,so plug either obd2 ecu and read the codes n go from there other then that your shooting in the dark..
                        do u have 2 o2 sensors?both iat sensors plugged in if u have both?it can be a list of things so get the codes down n start eliminating 1 by 1..
                          I haven't tried a non vtec ecu yet^
                            ok well try it and find out,remember as long as u have a cat an no cel they only plug the reader in the obd port not put in on the rollers like obd1's so u should be good...
                              Thanks for the info ill just pull the codes again and see
