Oil plug thingy
  • Oil plug thingy
    Sooooo.. what's this do? What's the plug hooked on the blue plug for? Usually I see those going directly into the engine itself.. not like this.
    It's the factory oil pressure sensor. When people do ls/vtec or b20/vtec or boost they take a cheap way out like the pic above and run a T fitting to run the oil feed line to the head or turbo. The best way to do it is a sandwich plate.
      its the oil pressure sensor and normally its in the block where the blue fitting is but you have a T fitting there for either a vtec head or oil feed line for a turbo
      dont worry its all setup right and nothing to worry about
        X2 I'd change it and do the sandwich plate like ls/vtec said
          ^^^x3
            I'd leave it alone. If its not broken font fix it, I've seen plenty of cars run fine like this...if I was going to do it myself I would use the sandwich plate though
              What everybody said^^^^
              Follow Me On Instagram
              Jdmkid618
                or fix it before it breaks! I've seen plenty of cars run like this fine. However i blew a motor from using one of the cheap kits. The oil line snapped off the head while driving. I've also seen people snap the T fittings off in the block while changing the oil filter of from vibration.
                  thats how they do it in indiana, huh? lol
                  BACK FROM THE DEAD
                  FUNCTION > FORM
                    thats retarded. Just get rid of it. Dont take up a port on a sandwitch plate for that.
                    By the time the stock light turns on, your motor is already toast. So just leave it the way it is or get rid of it.
                      x23456789
                      860....ALLDAY
                        i had one like that on my old da9 boosted for many years never broke or anything i use to comute about 55 miles round trip from and to work with no other driving around
                          at the end of the day if he wants to change it no one has a say so. I was always recommended to use a sandwich plate for either allmotor or boost, but w.e to eachs own
                            aaaahhh.... fml... shitty news... great :/. I thought it was okay but now that I read all this I kinda regret it now. Now I'm hoping it wasn't some beat up turbo'd engine like one of the one's I got screwed over with long ago. Everyone out here in IN and KY are out to screw each other over by the look of it :/
                              So what's a sandwhich plate? Sorry it's a stupid question but I've never heard of that and this is the first time I see something like this too.
