Search in B Series Tech only
Technical Forums
B Series Tech
ls help
ej1 pupe
Dec 2011
ls help
08-17-2012, 05:15 PM
My car idle at 3k and it won't go down wat can it be
Any help/info can help
EJ1 STILL BUILDING
088manolo880
Feb 2011
08-17-2012, 05:36 PM
Try the idle control valve on the throttle body, found right above the throttle plate hole. Its a flat head screw and if u turn it one way the idle will rise turn if the other way it will drop
088manolo880
Feb 2011
08-17-2012, 05:39 PM
Start there gl
elpepe
Dec 2010
08-17-2012, 05:52 PM
is a vacuum leak look at all the nipples on the manifold or maybe a leak between the had and manifold
93supercoupe
Nov 2008
08-17-2012, 05:53 PM
elpepe
x2
203CARTEL_NeiL
08-17-2012, 05:54 PM
HMU at 7 im at work right now.
Jovanni91Da
Feb 2009
08-17-2012, 06:02 PM
