Jdm b18c issues
  • Jdm b18c issues
    So I swapped a 97 spec Jdm gsr into my 95 Integra gsr so I used a ls harness obd2 and ran vtec and bypassed the oil pressure switch and I have a p72 ecu wen I start it it calls for knock sensor vtec shoots out codes 10 21 23 9 and I run my Jdm ecu p30 it's for a b16 and it jus. Calls for code 9 cilinder sensor idk and my vtec doesn't pop do I need a usdm vtec solenoid and a vteck harness let me know any help would appreciate it.
    First of all you need to figure out the codes. And work on that
    ~StayinFRESHSINCE1982~
    SPUNKY MONKEY CREW MEMBER #1
    203 CREW MEMBER #33
      What he said ^
      and if you are throwing a code for knock sensr, vtec will not engage.
        Wen I run the Jdm p30 it jus calls for a cyp sensor it's cylinder 1 sensor idk Wht it is but to do it the right way would be to get a new harness and usdm soleinoid cuz I have the oil switch bypassed too wen I use the usdm ecu it calls for the knock sensor vtec
          I figured it out thanks
            Wats was it
              I jus have to use a Jdm ecu it works with the Jdm b16 and ima replace the dizzy for the cilinder sensor the code 9 it was throwing
