b18a1 help
  • b18a1 help
    i was driving down the road and the gauge cluster when crazy car shut off and i re started it still rolling then died again now i turn it over but nothing happends like there no spark. any ideas
    91 integra
      Check ur sensons, harness,dizzy,ecu...gotta b one of those!!
        ^^check the harness n dizzy
        o.T.s
          I bet it's the coil in the dizzy
            Alternator??
            8thCivic.com
              That could b an issue to cuz he didn't mantion if the engine cranks over!!!
              Lol always gotta start from the most simple shitt
                shit use to happen to me all the fucking time i hate it
                  If it's. Da id say main relay or dizzy
                    i got my car back today it turns over but no spark i put a different dizzy on and still no spark. any ideas
                      u sure da diff dizzy u gots is good
                        i tested it with my friends off his car.
                          Try Changing the Ecu? Try Changing Spark Plugs They may have fowled out, Make sure the firing order is correct.
                          Check You're Main Relay.
                          And All Fuses Under Hood/ and Dash.
                          Down Since 09 ...
                          Mugen Inspired DC5
                            I second that check the coil
                              Check any grounds or plugs that came undone check ur o2 sensor also it cod be groundin out
