Gsr transmission stuck
  • Gsr transmission stuck
    my transmission got very hard to put in gear this morning it feels like the clutch is engaged when i push the pedal all the way down idk what it could be it did this before but it stopped when i drained and refilled the transmision oil and blead the clutch line 2 weeks ago but it came back
    is it a bad cmc or a bad csc or is it the whole clutch setup??
    have someone push the clutch and you watch the slave and see if it is moving all the way. A slave is like $15 at autozone. So I would just buy one to have a new one anyways. And a master i think is like $55. Chances are it's one of them if it went away when you blead it. Pull your carpet back by your clutch pedal inside and see if the sea on your clutch master is leaking.
      i think the slave cylinder is stuck or i messed the adjustment up in the clutch pedal or something cuz my starter is shot and to start it i hav to hit the clutch pedal real fast a good 20 times for it to turn on and i did that yesterday but started slamming the pedal down cuz i got mad and thats when it got all screwed up
      imma replace the slave cylinder today adjust the pedal and put all new clutch fluid in and im praying to god it fixes the problem
        slave and master replace
          Trans is beat. You wanna sell it? Lmao
            its not the transmission and even if it was its not for sale
              clutch
                could be a bad pressure plate
                  well imma give the slave cylinder a shot if that dnt fix it guess its bye bye to my rims
                    Lmaoooo my nigga crazy. Want everyone tranny lmaooo.. But def replace slave and master then if not that then its the clutch, do you beat on the car alot?
                    R.I.P Nick aka NHSwaps
                      not really i hav my fun with it from time to time like certain friday and tuesday nights but i usually baby it since its my daily
                        so i changed the slave cylinder and blead the clutch today and still it stopped for like 5 minutes literally then started back up again and now u can hear a grinding or rubbing noise when i put it in gear therefore i pretty much just came to the assumption that i need a new clutch setup now
