89 hatch turbo help
  • 89 hatch turbo help
    I have a 89 hatch with a stock ls,with a pr4 ecu and the car is obd0,what ecu and injectors will i need to find to run a turbo set up on it??Thanks for any info
    Powered by EF and EK blood!
    Lmao, you gotta put some managment in it. And it would be impossible to tell you what size injectors with out a power goal
      1000cc injectors n get a eBay turbo kit n leave the stock pistons in
        Well i had already turbo a 94 coupe ls that i had,i had a t3/t4 turbo,with a chipped ecu base map,450cc injectors and ran sweet,just dont know what ecu to use on a obd0 hatch
