i have 2 ls motors 1 is a b18a1 and 1 is a b1 the b1 has a spun bearing i was wondering if i could take all the internals out of the a1 and put them in the b1 and if so wat would be a good thing 2 change like rings etc thx
crank swap help
main bearings will need to be resized to the new block. just look up the crank/ block numbers and see what size bearings you will need. same deal if you are mixing the rods/ from the other motor as well . hone cyl/ re ring as nessicerry and obviously new gaskets and t/belt, w/p are always a good idea
