options on a rebuild
  • options on a rebuild
    so im doing a mild rebuild and was wondering if any of you have used these pistons before.. i'm getting blow by and not sure if its due to a bad piston and not just rings this kit is complete and im on a budget so dont knock me thanks
    Money Ain't a Thing! Crew Member #7
    Propperly installed with the with propper clearances yes it will work fine engine should be taken to a good machine shop to check for tolerance and correct ring gap then have someone assemble it for you and make sure that they know what there doing.
    860 member #18
    puerto roc #1
    Cosa nostra
    ASAPRadio.net
        Thanks Danny its one of his choices.because of the price its a gsr turbo btw
          Bump gl
          J.R. Built not Bought
            hasting rings and king bearings are reputable. with a good install youll be straight. i would take the block to a machine shop tho and have them inspect thoroughly before doing anything
            My work: Flikr.
            Andres Valentin Photography
              No prob and turbo then yeah it deff needs to be done propperly any questions lmk
              860 member #18
              puerto roc #1
              Cosa nostra
              ASAPRadio.net
