First start.. Wont start
  • First start.. Wont start
    got it
    maybe the lock cylender is broken.. But check the fuse on the pump
    96-ek hatch b20vtec - daily
      Ur name says it all lol "el abusador" jk. Bump help him out
        Upp
          Main relay is no good
            Test the realy... here u go http://www.justanswer.com/honda/1453...t-without.html
              or http://www.google.com/imgres?um=1&hl...:14,s:15,i:139
                uppppuppppupppppp.........
                  i think it might be that for the fuel pump.... but wat about the only one click on the ignition
                  cus once it hits the second click it tries to turn on the car.??
                    The ignition cylinder is fucked. I have a fresh one with keys if you want it 50 obo. Will include clean fresh ignition harness. Can be re keyed very simply with your internals.
                    Also, if the pump is not kicking on on the first click, it is because the relay is shot, the pump is dead, or there is an issue with wiring.
                    RIP NHSWAPS13203
                      I think is the relay ill check
                        check the fuse under the dash i believe its a 10 amp cuz that happened to me an it ended up being the fuse
                        fuck fake friends crew member #1....i love my h8terz, an those that talk with no cars!!
                          if not that then main relay or bad fuel pump
                            i'll send u my # when i get back from the gym
                              Upp upp upp
