Watsup ctv got a noob question.i have a 95 eg coupe and im putting a 98 ls swap in it with hydro tranny.my boy has b16 linkage that came off an ek.im just wondering if i can use that linkage.i was told all b series linkage is interchangeable but i just want to be sure.thanks
Shift linkage question
they are the same with the exception of ef, da, and del sol.....ef use their own aftermarket usually hasport or custom weld....da are close but use their own stock set up....del sol is a dealer only peice or aftermarket.....ek and eg both use dc teg linkage....main diff between all is the length and sometimes the bends are slightly diff.....gl with your build
