bseries vtec issue
  • bseries vtec issue
    i have a 98 gsr stock with an exhaust...oil levels r good, just changed plugsand cleaned out the vtec selenoid
    car will pull through vtec in 1st but at higher gears vtec will break up and sometimes will fall on its face, throwing a p1259 for vtec malfunction
    any info will help, thanks in advance
    2o3 crew member #30
    93 captiva DA9
    GHK all day #7
    RIP NHswaps13203
    That code usually comes around when the solenoid is leaking either internally or externally or even sometimes if the engine has a pressure drop due to many different things.
    I would go get a cheap oil pressure gauge mechanical and run the car into the VTEC range and see if the pressure is around 50+psi.
    It could also be a bad VTEC pressure switch.
    You could also test your solenoid. Easy to do if you have jumper wires. Power your solenoid with 12 v then ground it. You should hear a clicking sound. If not then replace it.
    If you need help hit me up 203-215-8996. I have a shop in new haven and i can figure it out.
    RIP NHSWAPS13203
      BUmp for dudes like this guy that took his time to help another memeber out if there was more like this dude the game would be alot better bummmmmp for a helping hand
      HATERZ EAT A DICK
        highly appreciate the help ill run through those things and if i have any ?s ill give u a call
        2o3 crew member #30
        93 captiva DA9
        GHK all day #7
        RIP NHswaps13203
          You know who this is right?
          RIP NHSWAPS13203
            Always my brotha..
            RIP NHSWAPS13203
              cant say i do
              2o3 crew member #30
              93 captiva DA9
              GHK all day #7
              RIP NHswaps13203
                cant say i do
                Fat Nick
                RIP NHSWAPS13203
                  oh what up dude...
                  2o3 crew member #30
                  93 captiva DA9
                  GHK all day #7
                  RIP NHswaps13203
                    Not a damn thing busy as hell just got a shop so ive been busy busy
                    RIP NHSWAPS13203
                      Fat nick and johnny blaze! What up!
                        Bro i got my own shop in new haven now. BIG AS FUCK
                        RIP NHSWAPS13203
                          What's crackin
                          2o3 crew member #30
                          93 captiva DA9
                          GHK all day #7
                          RIP NHswaps13203
