b20 q?
  • b20 q?
    Quick question.. I got a 98 crv and I picked up a Jdm b20 that I wanna put in soon. My question is can I just swap the crank sensor? I know Jdm motors don't come with them so I wanna know if I can just put it on and keep it moving.. I don't want a cel.. lmk ctv!
    Swap the oil pump
      Then keep it moving
        gotta swap the oil pump with crank sensor and add a knock sensor
          and keep it moving
            98 crv's didn't use knock sensors 99-00 did with the b20z
              What they said ^. You need a oild pump for a obd2 teg or em1. Or even a crv. Cuz it has the spot for the crank sensor.
                I have the old motor wit the crank sensor.. so just swap oil pumps and I'm good?? And my crv is 98 and has a crank sensor...
                  Yea. The only reason you have to put a new oil pump is because the crank sensor bolts to the oil pump. And jdm oil pumps don't have the spot for the crank pos sensor to bolt to. Neither do obd1 oil pumps.
                    Bout to just buy a new one from Honda..
