Help with b swap
  • Help with b swap
    Watup ctv i got a 95 eg coupe and it had d16z6 obd1 swap but i just got a 98 b18b obd2(non v)swap for it minus dizzy and harness.what im trying to figure out is if i should go with obd1 or obd2 and if so what will i need so that its all plug and play.
    Ej1 b18 sleeper,Ej2 z6 daily,Ek9 y8 ladys car.Built not bought...
    i would go obd2 cause thats already what you have just get an obd2 dizzy and obd2 INTEGRA harness everything is plug and play
      The obd2 harness will plugg rite in to the harness before the fire wall?
        yes an OBD2 INTEGRA HARNESS IS REVERSE COMPATIBLE WITH EG! has to be an integra harness not EK...
          Ok and what ecu should i use?
            If it were me i would use your existing harness and go odb1, get some 0db1 clipped injectors and dizzy, i think you might have to use an older year iacv too...if you go that route
              you will need
              obd1 p75 ls ecu which i have if you dont have one
              and i also have the obd2 ls dizzy lmk
                Ok i just wanted to be sure cus i dnt wana buy parts for no reason lol...thanks for the help guys!!
                  Don't mean to bud in but I am also doing a b swap its a b20 out of an auto crv,do I have to do some kind of engine mount conversion or can I just use stock manual b series mounts ?
                    I think u would use the same mounts im using but a different t bracket
                      What mounts are you using?could it be an ls integra bracket and mount?
                        Im using b18 mounts but i thing b18 and b20 mounts are the same
                          What mounts are you using ?could it be an ls integra bracket and mount?
                            it goes in like in ls that all it is a bored out ls
                              ^^ bingo
