Obd1 Swap help?
  • Obd1 Swap help?
    Ok so im doing an obd1 ls swap on my ek. What do i need to change to make it obd2? Also what mounts and harnesses i need to buy in order to make this run perfect? I know i have to change the dizzy and alt. but what else do i have and what ecu to run on too.? Thanks.
    Get an obd2 motor... Ur going to get Crank sensor cel. Use the harness u have now.. Si t bracket Si post mount
      ^wht he said but u can bypass the crank so u can us that swap jst get the obd2 ecu
      BFAM-racing#2
        You can use p2p ecu
          thanks for the imput. motor is stock imma leave it like that for a while until i get funds to build it up.
              Google it, Honda tech.. Do some research before u start making threads.
                Bump if u need more help Lmk me n my boy doing same swap so if anything Lmk done this too many times lol
                integranation member #8
