Stripped Threads b16 block
  • Stripped Threads b16 block
    Close
    ANd is there anyone on here that is nice at fixing this? like putting helicoils or timeserts in? lmk thanx
      one word heelecoil i think thats how writed if not wrong either that or machine shop
        thanks bump need more opinons
          you can helicoil it or just tap it with the bigger american size and then drill the mount out a little bit to accept the bigger bolt.
          Do it before you start driving.
            Yah don't drive an make it worse .. Happened to a friend of mine .. Either tap an re thread or tap an use steel sleeve don't "heli"coil b/c there not as strong as taping an using steel sleeves
              a keen sert would be best if you have the material to use it
              http://www.mcmaster.com/#key-locking...nserts/=gvy9n4
              Ef/Ek/DC5
                link for helicoil and helicoil repair kit
                http://www.mcmaster.com/#helicoils/=gvydaz
                Ef/Ek/DC5
                  ya thats the thing i dnt wana use a bigger bolt
                    I work at a machine shop
                    Originally posted by spoon_ek
                    i took one of the bolts out from the driver side mount bracket today on a b16 motor and noticed the threads in the block are stripped....if i have the two other bolts in will i be good driving the car everyday until i can get it to the machine shop? Need opinions thanks
                    in the mean time im most likely gonna thro the torque mount back on also just to b safe
                    also if someone would know what size helicoil or w.e i need to buy thanks
                    there no need to go to a machine shop... First find the thread size and bolt size then go to ur local hardware shop and buy a taper it 10.00 most or less way cheaper then going to a shop... All u need is a drill some lub and the tap.. All the tap does is re thread ur hole make it a good as new
                      U can find the tap that will just simply re thread it and keep the same bolt.. Trust me i work in a machine shop and deal with taping and striped thread if u want me to do it i can for free it will take 2 min if that
                        Ya but wat if i dnt want to tap it how would i got bouts putting in a timesert
                          i have the exact same problem right now except with the left bolt. ive been driving around for 3 weeks now fine with torque mounts in too. its in there but only by a few threads, it gets barley tight then loose again. so i think the best thing is to just re tap it like dccrew said, its deff the easiest fuck helicoils and shit.
                            Ya but like half the thread came out with the bolt and jus fell off...still can use same bolt? and ill give u w.e how much money u want if u fix it for me
                              thanks brotha
