timeing dumb question
  • timeing dumb question
    Ok so I'm doing a head replacement on my ls but engine is in the car trying to set it to TDC but I can't see the pointer on the lower cover. Any one no a better way to check for TDC. I tryed lineing up the cams but look like one jumped a tooth so no luck. Or a way I can see the pointer
    Text:8604810204
    pull the plug in cylinder number one n use the dipstick to make sure its tdc
      X2 or pay someone so you don't break anything
        ^ x3 thats basically the easiest way
          did the dipstick n rotor its the cam thats throwing me off dont no how the gear is off got the car that way, cant learn if u never do it urself
          Text:8604810204
            Pull the belt off and line the cams back up
              The cam gears have marks. Its easy.
                the up marks must be up and each cam has a little tiny line u need to have those line up and take the cover off at the bottom of tha crankshaft pulley u can see the marking on the block and good luck its a pain in the ass
                  to tell u the truth on a bseries when u look at the cams sprocket one looks slightly off about a tooth....even though it looks so it really isnt.....i assume the cam that looks funny to u is the exhaust cam....thats the one thats supposed to sit that way before u put the belt and tighten tensioner.....its hard to really explain but u really should get someone who knows wut they doin to actually show u...that way u wont break anything and you will learn how its done....
                    There's also holes on top of the cam to insert keys
                      true niceguy did that wit mines n it worked
                        That's the easy fast way. Lol ^^
