help b20 won't stay running
  • help b20 won't stay running
    What's up guys, so I've done my swap it starts up fine runs mint but won't stay at idle it seems like its too low. i swapped out the dizzy could it have anything to do with that? I can get it to stay at idle but its very tricky and if i just tap the gas and let go it stalls out. any advice would ne great thanks.
    Up
      Vacuum an compression test ??
        check the timing then adjust the idle screw
        Ef/Ek/DC5
          Give me 40 n I'll fix it lol
            Do u have aftermarket fuel rail,fuel injectors?and fuel pump?with a stock ecu?
              Try adjusting your throttle cable,and do wat 70stunt told u 2,it has to be one of those things
                only aftermarket fuel rail and fpr, using stock injectors and right now regular pump gas until i can get to the station for premium. im running on a chipped p28 with a type r base map set up close as possible for b20v
                  Did u time your dizzy ?
                    no.. and im guessing thats what the problem is
                      Turn your dizzy back a lil it could be that 2
                        Are the map and iac plugged in the right place?
                          Iacv colors yellow/black blue/white
                          (860) and beyond
                          #DavesTuning 8608050968
                            ok so i got it to stay idleing by messin with the dizzy a little bit runs nice and smooth but idles at like 500 if not lower
                              is there a idle adjustment screw? is tps voltage set correctly
