gsr tranny fluid
  • gsr tranny fluid
    ive been doin research and get mixed reviews so i wanted to know that you guys think. here are all the types of fluid people said were ok to use
    Honda oem MTF
    Gm syncromesh with friction modifier
    mobile 1 10w30 synthetic
    penzoil syncromesh
    lucus oil synthetic
    so i just dont know what to use. i would use honda mtf but i have no way to get to honda closest one is half hour away.
    do not use synthetic its not good for honda trannys
    but ive always used pennzoil syncromesh and never had a problem with it
      full 2 qt or mixed with anything?
        honda MTF. theres no exception, unless its a single, lmao
        Just get it on ebay bruh, way cheaper
          i just use 2 quarts but it take like 2.3 for b series trannys
            i dont have time to wait. ive dont my fair share of research and although alot of people say what you just did, a lot also say pennzoil works just as well
            thanks for your input man
              10/30 non synthetic if u can't get to Honda for mtf
                Gm syncromesh with friction modifier is the best but its $18 per quart next is the oem mtf ******when you use the Gm syncromesh with friction modifier the tranny doesn't feel notchy,,,,,
                  Just use some 10-30 for a few miles get everything flowing and get u on ur feet. Then go pick up Honda mtf
                    Follow me @bolacan413
                    Follow the build @k_insight
                      HONDA MTF all day!
                        thanks guys
                          Honda mtf is the only way to go!!!
                            I use lucus oil synthetic n never has a problem n was alway Beatin on it
                              ive used everything you can imagine and never noticed a diff
                              CT'S Fastest Coupe
                              9.94@ 147
